Wearable 智能可穿戴
您现在的位置:首页 > 产品万花筒 > 微型无刷伺服电机
微型无刷伺服电机
关键词:伺服电机电机控制电机控制驱动器
来源:互联网    2015-09-28
原文:英文
Moog Compact Dynamic Brushless Servo Motors are designed for highly dynamic servo applications where positioning times of 30 mSec or less are often the norm. The Moog Compact Dynamic Brushless Servo Motor offers one of the industry’s widest power ranges with standard models available at continuous stall torque ratings from 0.15 to 77 Nm (1.3 to 681 lb-in). The modular design is supported by a variety of options with Moog application engineers capable of supplying fully customized solutions.
Features
  • AC Servo Motor (Synchronous)
  • Low inertia, compact length
  • Type of Motor: Totally enclosed, natural cooling (optional fan ventilation)
  • High voltage (600 Vdc Brushless Servo Motor) available
  • Flameproof servo motors available
Benefits
  • Superior dynamics improves cycle time
  • Compact, lightweight
  • Proprietary low-cogging design
  • Rugged, minimum maintenance
  • Flexible design
Measuring Unit Compact Dynamic Brushless Servo Motor
Continuous stall torque M° Nm [lb-in]
0.15-77
[1.3-681]
Peak torque Mmax Nm [lb-in]
0.5-240
[4.4-2124]
Rated Speed nN min-1 [rpm] 9000-2200
Rated Power PN kW [hp]
0.13-12 [0.2-16]?
Rated Torque MN Nm [lb-in]
0.14-48 [1.2-425]?
Moment of Inertia J Kg cm2
[lb-insec2 x 10-4]
0.09-152 [0.8-1345]
Position transducer
Standard
Optional
Resolver
Encoder
Temperature monitoring
NTC or PTC
Brake
Optional
Rated bus voltage Vdc
V
325/565
Certificate/marks
CE, UL/cUL
Cooling
Natural
自动翻译仅供参考
微型无刷伺服电机
穆格紧凑型动态无刷伺服电机是专为高动态伺服应用,其中的30毫秒以内定位时间往往是常态。穆格紧凑型动态无刷伺服电机提供了业界最广泛的功率范围与现有的连续停止扭矩额定值范围从0.15到77牛米(1.3~681磅英寸)规格型号之一。模块化设计是由各种具有能够提供充分的定制解决方案穆格应用工程师选项的支持。
特征
交流伺服电机(同步)
低惯量,紧凑的长度
电机类型:全封闭,自然冷却(选配风扇通风)
高电压(600伏直流无刷伺服电机)可
提供矿用隔爆型伺服电机
优点
卓越的动力提高了循环时间
结构紧凑,重量轻
专有的低齿槽设计
坚固,最少的维护
灵活的设计
测量单元紧凑型动态无刷伺服电机
连续停止转矩Ma°牛米[磅 - ]
0.15-77
[1.3-681]
峰值扭矩M最大Nm的[磅 - ]
0.5-240
[4.4-2124]
额定转速NN分钟-1 [转] 9000-2200
额定功率PN千瓦[HP]
0.13-12 [0.2-16]
额定扭矩MN Nm的[磅 - ]
0.14-48 [1.2-425]
转动惯量J公斤平方厘米的瞬间
[LB-insec2×10-4]
0.09-152 [0.8-1345]
位置传感器
规范
可选
解析器
编码器
温度监控? NTC或PTC
刹车可选
额定母线电压Vdc
V
五百六十五分之三百二十五
证书/标志
CE,UL / cUL认证
冷却固有
我来说两句
