Wearable 智能可穿戴
您现在的位置:首页 > 产品万花筒 > 直线电机
直线电机
关键词:电机控制直线电机电机控制驱动器
来源:互联网    2015-09-28
原文:英文
Precision, Powerful Linear Motion
Moog linear motors are the solution for highly dynamic and precise linear motion positioning.
Our linear motors are a high force, direct drive solution which maximize positional accuracy while minimizing maintenance costs. With rugged construction designed for the harshest of factory environments, Moog's linear motors will extend mainteance intervals and reduce the cost of ownership of any linear motion system.
With only a single moving part and available non-contact position sensing, the number of wearing parts are reduced significantly with respect to traditional linear motion systems. Factory installed integrated bearings will provide long lasting operation for years of service with minimal downtime.
Features
Encoders with 0.1 μm resolution, optical and Hall types available
Complete systems including motor, encoder, drive, controller, cable and filters
High force motors up to 4,500 lbf [20 kN] force
Light duty motors for lower force applications with same durable and rugged construction
Fan cooled and liquid cooled options for maximum performance
Custom designs for any application
Model Diameter Over Standard Cooling Fins
(inches) Weight(lbm)* Peak Force
1 sec
(lbf)** Peak Current
1 sec
(A) Standard Stroke (inches)***
40202C 6.20 31 410 45 20
40202D 6.20 ?31 410 90 20
40204C 6.20 44 850 45 16
40204D 6.20 44 850 90 16
40206C 6.20 58 1180 45 12
40206D 6.20 58 1180 90 12
50202C 7.20 41 360 50 20
50202D 7.20 41 360 100 20
50204C 7.20 58 780 50 16
50204D 7.20 58 780 100 16
50206C 7.20 81 1100 50 12
50206D 7.20 81 1100 100 12
Weight – add 0.62 lbm for each inch of stroke
Consult Factory for continuous force capability of standard configuration motors as well as fan and liquid cooled options
Consult Factory for stroke lengths in excess of standard values
自动翻译仅供参考
直线电机
精密,功能强大的直线运动
穆格直线电机是高度动态和精确的直线运动的定位解决方案。
我们的直线电机是一个很大的力,直接驱动的解决方案,最大限度地提高定位精度,同时减少了维护成本。凭借坚固的结构设计为最恶劣的工厂环境中,穆格的直线电机将扩大mainteance间隔和减少任何直线运动系统的总体拥有成本。
只有一个单一的运动部件和可用非接触式位置感测,易损件的数目相对于传统的线性运动系统显著降低。工厂安装集成的轴承将根据工作年限以最少的停机时间提供持久的运行。
特征
编码器具有0.1微米的分辨率,光学和霍尔类型可用
完整的系统,包括电机,编码器,驱动器,控制器,电缆和过滤器
高力电机高达4500磅[20千牛]力
轻型电动机较小的力应用相同的持久和坚固的结构
风扇冷却,冷却液为最佳性能选项
定制设计的任何应用程序
型号直径超过标准散热片
(英寸)重量(磅)*峰值力
1秒
(磅)峰值电流
1秒
(一)标准行程(英寸)
40202D 6.20?31 410 90 20
重量 - 增加0.62磅中风的每一寸
咨询工厂标准配置电机的持续动力性能以及风扇和液冷选项
超出标准值的咨询工厂行程长度
我来说两句
